No keyboard function after water damage
My MBA M1 had water damage and I was able to restore functionality to almost everything by drying it out and then cleaning the visible PCB components with IPA (no disassembly apart from back cover). I used it for a few months but recently the keyboard stopped taking any input (touch ID button is fine). I'm able to plug in an external keyboard and use the computer normally otherwise. I disassembled the logic board and IPA cleaned its components plus all the trackpad and keyboard connectors to no avail.
What should I try at this point? I have another functional identical MBA. I was thinking to try swapping its trackpad/keyboard keyboard over to the MBA in question and seeing if that resolves it. I'm reticent to swap the good keyboard over to the bad, but if the component likely needs replacement I'm happy to purchase one to install. I just don't know whether that's the likely problem and whether or not it'd be DRM blocked or not...
Muchos gracias in advance!!
Esta é uma boa pergunta?
