Ir para o conteúdo principal
I need help with MacBook Air (2011) online recovery
when I boot my mac it comes up with the folder with a question mark (I had windows installed and then I wiped it) so I hold down option + command + r and then select install Mac OS from online recovery and it says “unable to install max os recovery server can’t be contacted” I checked my internet it’s working so what could it be I also tried command + r and it didn’t work and I tried a pram reset are the servers offline what do I do play help
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Instead of holding down option+command+r, try holding down just command+r. This will enter the normal recovery mode instead of internet recovery mode. From here you can follow the same steps as normal to reinstall MacOS, but instead of doing it through the internet it will install from a recovery partition on your Mac. It may be a slightly different version of MacOS (I believe it is MacOS Lion on this specific Macbook.) However, after installing MacOS X Lion you can then upgrade via the app store or whatever other methods you wish. If you need any more help, don't hesitate to ask!
Esta resposta foi útil?
Pontuação 0
Depending on the version of macOS your system is running you may not have the recovery partition. You likely lost it when you installed Windows.
The best way is using a second Mac create a bootable OS installer USB thumb drive. Do you have access to a 32GB thumb drive and a second Mac system to create the needed bootable installer?
Pontuação 0
Adicionar a sua resposta
Dunkochino será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 12
Ao todo: 133
