Ir para o conteúdo principal
A compact digital camera with dual view LCD displays and manufactured by Samsung.
1 Perguntas Visualizar todos
Why did my battery filled with air?
I had this camera for some years, and i haven't chnaged the battery, only charging it. As i wanted to change the battery i noticed no metter if i get the pin that was supose to make it fall from the slot, it wouldn't come off, i shaked thinking i could get it out but it didn't work. As i was inspecting the outer of the camera i noticed the left-down part from the front of the camera was weirdly stick upwards from the camera, so after some unscrewed i realized the problem was that the batery somehow got filled with air. Can anyone help me pls?
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Pergunta mais útil
It is not uncommon for lithium ion batteries to swell as they age. The electrolyte inside that carries the current begins to decompose and that process generates gas causing the battery to swell up. It's an unfortunate fact of life with Li-Ion batteries as they get old and near the end of their life.
What you don't want to do is to puncture the membrane to "let the air out". That can easily cause the battery to catch on fire, and believe me, lithium burns very well and very hot, so you don't want to do that. Remember the Galaxy Note 7?
Ultimately you may have to disassemble the camera far enough to be able to get the old battery out without damaging it. If you have to deal with a swollen battery, be sure to take precautions against the chance of it catching fire; a bucket of sand or a fireproof pouch would be good to have on hand. DO NOT put it in water; that will just make things worse! Here's a Wiki article on dealing with them that is well worth your time to read.
What to do with a swollen battery - iFixit
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Denix 54 será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 6
Duração total: 108
