Changed rear master cylinder now even after bleeding I stillDon’t have
Replaced rear brake cylinder now even after bleeding I have no pressure 2010 Silverado rear wheel drive
Esta é uma boa pergunta?
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 3
Duração total: 44
2 comentários
Found out that the new cylinder blew out Not understanding why this happened.
por richard fritts
If by new cylinder you mean a wheel cylinder inside the hub of a set of drum brakes then most likely you did not adjust the brakes properly after you repaired/replaced the wheel cylinder. The brake shows were allowed to spread far enough so as to let the new cylinder come apart.
por Thomas Stigall
