Ir para o conteúdo principal
Apple's top-of-the-line flagship for 2022. Released September 16th, the iPhone 14 Pro Max sports a 6.7" ProMotion OLED, the new Bionic A16 chip, a triple rear camera system, and 5G connectivity. Successor to the iPhone 13 Pro Max.
20 Perguntas Visualizar todos
iPhone 14 Pro Max restarts randomly after screen repair
Just randomly restarts every 5 or so minutes. I checked the battery connector and display connector. I did rip the front assembly connector, but I was told it would be fine without it. Just the proximity sensor wouldn’t work
Esta é uma boa pergunta?
Pontuação 2
Adicionar um comentário
2 respostas
Pergunta mais útil
Hi Travis,
On the iPhone 14 the proximity flex cable will cause a kernel panic if the sensor on it cannot be read, which is exactly what's happening with your reboots. If you actually time the reboots, you'll find they're happening every three minutes, which is the interval in which the phone checks its sensors.
You can read all about it on the iPhone Kernel Panics wiki page here.
iPhone Kernel Panics - iFixit
The upshot is your information about the torn proximity flex cable was incorrect; your phone is going to reboot itself every three minutes from now to eternity until you replace that part. Here's what you need.
iPhone 14 Pro Max Proximity Light Sensor Replacement – Repairs Universe
Esta resposta foi útil?
Pontuação 3
While replacing my screen the proximity light sensor ribbon cable broke. Thinking not a big deal I’ll just have a feature I can’t use. My phone would turn on work for a few minutes then freeze, give the pink screen of death and reboot. This article helped me understand what was going on and the linked replacement part was reasonably priced and arrived quickly. Thankfully the new part resolved my issue as the stores near me said the only fix was an entirely new phone.
Pontuação 0
Adicionar a sua resposta
Travis Cunningham será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 19
Últimos 30 dias: 116
Duração total: 1,851
