Ir para o conteúdo principal
Informações sobre reparo, desmontagem e solução de problemas do iPhone 15 Pro Max, o principal smartphone top de linha da Apple, lançado em 22 de setembro de 2023. Ele apresenta uma tela OLED ProMotion de 6,7", um sistema de câmera traseira com uma lente tripla e um novo periscópio de zoom óptico de 5x e 5G. Sucessor do iPhone 14 Pro Max.
20 Perguntas Visualizar todos
New iPhone Max Speaker Max Volume
I noticed that the iPhone 15 seems to ship with a phone call loudspeaker sound set at max. I've had two now, and when making a first call on each and putting on speaker, it was per set at max loud volume.
It was a little annoying, but it led me to wonder if a call or music at max volume would harm the speakers. I can only assume that Apple has thought of that and made sure it operates within safe limits, but the internet seems to think you can damage them. Wondering what you folks think?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Modern smartphones are designed with speakers that can handle a wide range of audio volumes without sustaining damage. Manufacturers typically ensure that the maximum volume level is within the safe operational limits of the speakers. This means that even at the highest volume, the speakers should not be damaged under normal conditions.
However, while occasional use at maximum volume is unlikely to damage the speakers, consistently playing audio at such high levels can potentially shorten the lifespan of the speakers. This is due to the increased wear and tear on the speaker components when they are consistently pushed to their limits. At max volume, you may experience a decrease in audio quality, characterized by distortion or a muffled sound. This is not necessarily indicative of damage but rather the speaker struggling to reproduce sound clearly at high volumes.
Apple may also include software limitations to prevent the speakers from reaching a volume that would cause damage.
TL;DR Speaker shouldn't be damaged unless consistently playing audio at max volume, but even then it is likely that Apple has implemented some software that would limit the potential for any issues.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
J T será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 3
Duração total: 136
