Kernal Panic iPhone 14 Pro, error code is not documented
I have an iPhone 14 Pro that was totally destroyed, but still powering on. After transfering to a new rear housing w/new charge port and screen it now hard resets every 5ish minutes and makes a panic log. The log is attached below.
The sensor string in my case does not seem to be well documented, but I am somewhat sure it will require board repair. Any guidance on what needs to be replaced to fix this issue would be greatly appreciated.
panic(cpu 2 caller 0xfffffff067d771dc): SMC PANIC - ASSERTION FAILED: target/d73/target.cpp:265: 0, SMC BSC failure, spreadsheet ver(*10) 140 S.sensor array 0 - 4 is 0x0, 0x120000, 0x0, 0x0, 0x0 F.sensor array 0 is 0x0 - Misc(2) OUTBOX1 not ready ASSERTION FAILED: target/d73/target.cpp:265: 0, SMC BSC failure, spreadsheet ver(*10) 140 S.sensor array 0 - 4 is 0x0, 0x120000, 0x0, 0x0, 0x0 F.sensor array 0 is 0x0
Esta é uma boa pergunta?
