Yellow display due to missing SMD resistor. Resistor value WANTED!
I have a yellow display and it turned out that an SMD resistor on the motherboard had broken out. Unfortunately I don't know the resistance value and I would be super grateful if someone could measure this resistance value. Please write whether you measured the resistance when installed or removed.
The resistor is located directly on the mainboard just below the connector for the display and is covered by this connector as long as it is plugged in.
Thank you very much and Christmas greetings 😊
Esta é uma boa pergunta?
