Ir para o conteúdo principal
Nintendo's upgraded version of the Nintendo 3DS. It features bigger screens, longer battery life, better pixel density, and a better design.
A button is not working
Hello,
After some time I wanted to play with my 3DS XL, but for some reason the A button is not working anymore. Everything else is working. I don't really understand how it happened since it was in its protective cover.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
Have you tried taking it apart and cleaning the membrane with ipa ?
Update (12/20/23)
@alix25904 Nintendo 3DS XL Power Button Replacement it should be pretty simple if you follow the guide
Esta resposta foi útil?
Pontuação 2
4 comentários:
I haven't tried anything yet since I'm not comfortable with the idea of opening it without knowing what to do, but I'll try this and post an update, thank you !
por
I fix it has tear down guide use it so you don’t break the console
por
You might need a tri wing screwdriver
por
So here's my update : I took it apart, and I cleaned it but it seems like it's the motherboard that's faulty, so I guess I'll just bring it to a repairer. Thank you for your help !
por
Adicionar a sua resposta
Alix será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Ao todo: 118
