Ir para o conteúdo principal
Guides for the Wi-Fi version of the iPad mini 5—model A2133. Released in March 2019, the iPad mini 5 is the successor to the iPad mini 4.
Digitizer not working after replacement
I bought a replacement Screen and digitizer The screen works great but the digitizer docent some spots don't register on the left and right in portrait mode and in regular mode I can't see ANY damage The connector looks good. Is there Something you have to cover or is it apple's prioritization
Esta é uma boa pergunta?
Pontuação 0
1 comentário
don't have the original screen but the old digitizer worked perfectly except it was cracked and the display
por
Adicionar um comentário
1 resposta
Pergunta mais útil
You didn't mention if you had cleaned the connector with some 90% or higher isopropyl alcohol, but other than that it looks to me as though you've covered pretty much all of the diagnostic bases.
At this point I would communicate with the seller of the replacement screen on the issues you're having with it and see about getting a replacement, especially given that you didn't have digitizer issues with the original screen.
Esta resposta foi útil?
Pontuação 1
1 comentário:
thanks I cleaned it am waiting for it to dry. let you know if it works.
por
Adicionar a sua resposta
Alistair moran será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 6
Ao todo: 157
