Ir para o conteúdo principal
My iPod isn't charging or responding to Itunes
I think it is a problem with the logic board, where you plug in the cable to the ipod it looks a little beat
Esta é uma boa pergunta?
Pontuação -1
3 comentários
Yes, we have tried 3 different cables.
por
in that case, it looks like a dock connector repair to me.
por
Have you tried a different ipod cable
por
Adicionar um comentário
1 resposta
Pergunta mais útil
dtomas, follow the advice given by Roshan first, if that does not help, and if you are certain your dock connector is "beat", it might be time to replace it. You have to remove the logic board and then desoldering the 30 pin connector, also desolder the 2 side anchor points. After that you resolder a new connector. This is not an easy job and will require sound soldering skills and proper tools. Take a look at this video and see if it is something that you would try. Hope this helps, good luck.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
dtomas será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Ao todo: 733
