Ir para o conteúdo principal
Guias de reparo, manuais e ajuda na resolução de problemas para iPhone 11. Aqui você recebe tudo o que precisa para consertar por conta própria o seu iPhone 11.
Screen turning on after screen replacement
I've just replaced the screen on my iphone 11 and everything is mostly working fine except the screen is turning on about every 30 seconds. It then auto-locks just like normal and repeat.
I did lose two screws during my repair, the Y screw in the speaker sensor assembly and one of they Y screws on the battery connector bracket.
I haven't reopened the phone yet to see if anything else looks damaged. I'd like to avoid that so I don't need to replace the adhesive again.
What would you suggest doing next? Can you tell me what component my be affecting the screen this way?
Thanks
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
Sometimes a faulty LCD with ghosting issues can cause this. It turns on as an effect of 'thinking' the lcd was touched. I have had multiple displays doing all sorts of things by itself.
Try with another LCD - initially only connecting the LCD and not the FACEID flex. See if it turns on now. If it doesn't, try to install the flex cable as well.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
kylewd12 será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 15
Ao todo: 253
