Ir para o conteúdo principal
Getting the LCD back in casing
So I just replaced the LCD on an IPOD 4g everything turned out great. The lcd and everything is working fine im just having trouble getting the screen entirely into the casing. I dont wanna force it to much because I dont wanna crack the LCD because its very thin. I feel like when I try to push the bottom of the screen in the top pops out anyone have any tips on this. Thanks in advance :)
Esta é uma boa pergunta?
Pontuação -1
1 comentário
I cant figure this out I even took out the metal plating and put the LCD on top and it still doesnt seem to wanna fit in there correctly.
por
Adicionar um comentário
1 resposta
Solução escolhida
I would lay it down flat on a table face down to make sure the casing wasn't bent then the other two things I would check are that the little speaker assembly at the bottom of the unit is put properly under the lip and second that the metal piece that is affixed to the top of the digitizer is placed correctly.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Arron Mayers será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 25
Ao todo: 552
