No HDD in HDD bay, but Disk Utility sees SSD
No HDD, cradle or SATA power/data cable seen in HDD bay. But Disk Utility sees Apple SSD SMO256G PCI internal physical disk.
How do I add new SSD?
Where is SATA power/data cable?
Need to get SSD cradle and SATA power/data cable?
Update (11/21/23)
Further research suggests that this iMac could have had a Fusion Drive (combining a hard drive and flash storage in a single volume), but no was HDD installed? Or it was removed?
This iMAc likely has flash storage (SSD) on mother board, can it be replaced?
I will look for SATA data/power cable, under the fan and HDD enclosure area.
If it is not there, can I install SATA data/power cable?
Esta é uma boa pergunta?
