Changing brake pads and rotors
How to replace brake pads and rotors
Esta é uma boa pergunta?
You jack the car up, remove the wheel, remove the caliper, remove the rotor, clean things up a bit, put the new rotor on, remove the pads from the caliper, clean it up, verify caliper operation, replace rubber seals if necessary, grease up the slides, grease the back of the pad, put the new pads in, put the caliper back, put the wheel back, lower the car, repeat 3 more times. There is likely a video on YouTube.
Esta resposta foi útil?
Últimas 24 horas: 3
Últimos 7 dias: 10
Últimos 30 dias: 35
Ao todo: 925
