Ir para o conteúdo principal
The Aspire 3 A315 is a repairable laptop by Acer.
20 Perguntas Visualizar todos
Doest start completly and in few sec it restart repeatedly
It does't start completly but you can hear the fan and HD works only in a few sec , then it sart again same before no boot or display on screen... btw the screen is already broken but i used tv as external monitor (i mention it so you don't need to suggest that the monitor is the problem ) and it works without hustle.. The problem only occur after i clean up the fan. I remove the fan carefully and put it back just like i normaly do every time i clean it up.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Is a Keyboard issue. The power button is on a keyboard, and if he fail, the laptop don't boot up, and sometimes enter in a loop, because he thinks a power button is pressed
Try this My keyboard is not working
Esta resposta foi útil?
Pontuação 0
Oh thanks. But i already figure it out. It just happen that i need to change thermal grease.. The termal grease just dried out and create over heating thst force my device to shut down..
Pontuação 0
Adicionar a sua resposta
Alfred Addur será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 3
Duração total: 63
