Ir para o conteúdo principal
Repair, disassembly, and troubleshooting information for the Xbox Series S, Microsoft's newest small form factor, digital-only gaming console. The Xbox Series S was released alongside its more powerful big brother, the Xbox Series X, on November 10th, 2020.
Controller keeps connecting and disconnecting
As stated in title my controller will connect and disconnect continuously. The controller will work for 2 seconds then starts blinking. I have tried replacing the wifi module, and antenna module but it didnt work. I have also hard reset the console. Is there anything else i can do?
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Have you tried a different controller do you have the same problem on multiple because some controllers are known to die
Esta resposta foi útil?
Pontuação 0
1 comentário:
only controller i have, i might buy another and check, but when i connect controller to my phone it works fine
por
Adicionar a sua resposta
Gabe será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 10
Ao todo: 206
