Why is my phone only flashing when I plug it in or when I push power
why is my phone only flashing when i plug it in or when i push power ?
Esta é uma boa pergunta?
try pressing it for 10 seconds then the unit will automatically restart if the problem remains the same and there is no vibration, most likely the screen you have has a pressing or crushing problem before. then you can look again for the next step
Esta resposta foi útil?
It will only go to the download os screen for bootloader but nothing else I was told it was battery I replaced battery and it worked then I hooked charger to it and it went back to flashing only
OK i tried what you said it didn't work ....then i got it to work i swapped around parts on another and got both working just now the one doesn't charge it will say it starts charging but the the battery just flashes and i go to settings and it says connected not charging
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 27
