Ir para o conteúdo principal
A1706 / EMC 3071—Released in November 2016, this 13" Macbook Pro introduces the OLED Touch Bar. Features a dual-core "Skylake" Intel Core i5 CPU and four Thunderbolt 3 ports.
MacBook Pro with touchbar has 10cm line on the right
I have a 2016 mac book pro with touchbar
and it has a 10 line on the right side now I don't know wether it's hardware or software and is their somewhere in Australia that I can get a board from model is a1706
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Screen damage is very likely. This problem will be resolved if the screen is replaced, there is a possibility that it will fall or be crushed by another object
Esta resposta foi útil?
Pontuação 0
3 comentários:
I was going to do the screen anyway and while I am in their the battery will be replaced. And anything else that’s suspect looking
por
It's a good idea to replace it in a place that looks official because this kind of analysis is handled quite easily
por
@yusufdwi010199 - Is correct your display is damaged! Here's the needed part MacBook Pro 13" Retina (Late 2016-2017) Display Assembly and here's the guide to put it on MacBook Pro 13" Touch Bar Late 2016 Display Assembly Replacement
And yes your battery is likely near the end of its useful life. I would install this gem of an App CoconutBattery it will allow you to see things better than what Apple offers in its battery health function. Post a snapshot of it so we can see where you are now
In any case again here's the needed part MacBook Pro 13" Retina (Touch Bar, Late 2016-2017) Battery and the guide to put it in MacBook Pro 13" Touch Bar Late 2016 Battery Replacement
Given the costs of needed both you might want to look at getting a used newer system.
As for someone to do the repair if its too daunting for you, I would give Paul Daniels a try PLDaniels Repairs
por
Adicionar a sua resposta
josh será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 7
Ao todo: 142
