Ir para o conteúdo principal
The Samsung Galaxy A52s is Samsung's upgraded variation of the Galaxy A52.
How can I calibrate my fingerprint sensor
My Phone Fingerprint Sensor Calibration Need How Can I Fix It
Esta é uma boa pergunta?
Pontuação 2
Adicionar um comentário
3 respostas
If the sensor is not working, you will have to recalibrate your Samsung Galaxy A52s. This can be done in several ways. The first way is to go to settings and click biometrics. Then, select security. Scroll down to the fingerprint section. You will see the option to delete existing fingerprints. Erase all your fingerprints. This should clear up the problem. Then, you can try setting your fingers again.
Esta resposta foi útil?
Pontuação 0
How to open my handphone if i forget finger pattern
Pontuação 0
1 comentário:
you should post a separate thread. Yours isn't the same issue
por
Check this out
Pontuação 0
Adicionar a sua resposta
Android “EVILDevil” Imran será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 27
Ao todo: 1,077
