Ir para o conteúdo principal
The Samsung Keystone 2 increases the durability of its battery with a super long standby time of up to 30 days. Plus it is equipped with various useful features - FM radio, a unit converter which converts currency, length, weight, volume, area, and temperature). The phone also includes a calculator and MP3 ringtones for full and nice ringtones that alert you to incoming calls and messages. This phone was released in 2012 and is also identifiable by the model number QT-E1205Q.
After replacing with new battery phone is not starting
How check phone is dead or not
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
3 respostas
Check to make sure it is a legitimate battery. Also, if it's dead, it won't turn on. Try charging it, the turn it on again. If it doesn't work, try the old battery again to see if the new one has a fault. Hope this helps!
Esta resposta foi útil?
Pontuação 0
Try checking to see if there is still protective plastic on the battery copper
Pontuação 0
Not start switch off
Pontuação 0
Adicionar a sua resposta
Munna será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 9
Ao todo: 146
