Ir para o conteúdo principal
O Logitech 502 Lightspeed é um mouse gamer sem fio que compartilha a maioria das especificações com seu irmão com fio, o G502 Hero. Número do modelo MR0076. Lançado em maio de 2019.
Scroll wheel doesn't respond.
I used 70% isopropyl alcohol to remove fur on the inside of the wheel, but after waiting for the alcohol to dry, the scroll wheel started to respond less and less over time until now, where it does nothing.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Why use alcohol at all ??? In the future why not just use your fingers and small tweezers to pull out the hairs?
Another very important point is that 70% isopropyl alcohol is for disinfecting NOT electronics, as it has to much water in it often with minerals which leave deposits which can short electronic circuits. 99% or very close to that is preferred and is available at electronic component supply shops.
You may also have to wash the area with pure distilled water available as pharmacies. Make sure it is completely dry before using mouse again as water will short the electrical circuits.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Cadfg será eternamente grato(a).
Visualizações:
Últimas 24 horas: 7
Últimos 7 dias: 18
Últimos 30 dias: 62
Ao todo: 1,124
