Ir para o conteúdo principal
Any problems with the temperature sensor when replacing the HDD?
Hi,
I was reading a lot about upgrading the HDD but I am confused about the bit with the temperature sensor.
My understanding was that replacing the HDD with a new (larger) HDD will lead to the new HDDs fans running on full power because the temperature sensor cant be attached to the new drive.
Is there a way of avoiding that problem and install a larger HDD without having to deal with the temperature sensor issue?
Thanks.
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
2 respostas
Solução escolhida
You'll need to get your drive directly from Apple to avoid the temperature sensor issues.
Esta resposta foi útil?
Pontuação 3
I contacted an authorised Apple Service Provider and they said they could install a 2TB HDD for about 500 EUR.
Given that I paid around 1000 EUR for my iMac, I think that is insane!
The answer to my problem seems to be HDD Fan Control.
Pontuação 0
Adicionar a sua resposta
richard será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Ao todo: 672
