Ir para o conteúdo principal
The Xiaomi Poco X3 Pro is an entry level smartphone by Xiaomi released March 2021. It is equipped with a 6.67" IPS LCD screen, a 48 MP main camera and runs on the Qualcomm Snapdragon 860.
20 Perguntas Visualizar todos
My phone is not sporting fast charger
My phone is not spoting fast charger
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
While USB C is a standardized connector, the implementation of its spec may not.
Some charging bricks or cables while may advertise higher may not be able to provide it to your specific device, I would try them on different devices so you can single out the issue.
However first I would check in settings that you have fast charging enabled in the settings.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Nitish kumar Singh será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Ao todo: 79
