Ir para o conteúdo principal
Model A1347. Released on July 21, 2011. Core i5 or Core i7 Processor. Thunderbolt. This unit is also used to run the Mac mini Server configuration.
Problem with Mac Mini Dual Hard Drive Kit
Hello!
Sorry for my english..
I bought your Mac Mini Dual Hard Drive Kit.
After first connection, it worked fine!
I plugged the HDD (Apple default - Toshiba 500Gb) in your SATA cable. According to Apple SATA cable I have connected a new SSD OCZ VERTEX 120Gb and installed Mac OS X Lion.
A week later, HDD suddenly switched off and the OS does not see it in Disk Utility.
I made ​​out and reconnected, restart, and again it worked! But then again, at system startup, MAc loading for a long time, and the drive was not visible too.
I then changed the cable, HDD with data and SDD with the OS.
OS has booted, but sometimes it freezes for 3-5 minutes....
In the end, I disabled the second HDDdisk - I think that your SATA cable does not work stability
How can you help me?
Esta é uma boa pergunta?
Pontuação -1
Adicionar um comentário
1 resposta
Solução escolhida
Please Contact customer service. Have your order number ready.
If this Answer is helpful please remember to return and mark it Accepted.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
icemanea será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Ao todo: 1,024
