Ir para o conteúdo principal
{A1989 / EMC3214}—Released in July 2018, the 13" MacBook Pro features quad-core i5 and i7 processors and Intel Iris Plus integrated graphics.
space bar key is working
While cleaning, I removed the space key but it accidentally got detached from its hinge. Although the hinge wasn't damaged, I noticed that there was a gap in the key after reattaching it, which required me to press it harder each time to make it work.I opened a space key to clean but it got detached with its hinge the hinge was not damaged but when I attached it back there was a gap in the space key as I had to press it harder to work every time.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Often an Apple Store can pop the Space Bar back on, if the clips are damaged they can also replace the part/S as needed.
I would try them first as it’s often done for free. Going to a good independent Mac repair shop might take a bit of time and unlike the Apple Store who will often do it for the good PR the independent needs the income.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Mukul será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 5
Ao todo: 139
