Ir para o conteúdo principal
Repair guides, support, and troubleshooting information for the first 13-inch MacBook Air to feature Apple's ARM-based M1 SoC (with an 8-core CPU and up to an 8-core GPU). Released in November 2020 and identified by model numbers A2338 or EMC 3598.
Replacement Keyboard not working
After a coffee spill the keyboard stopped working. The track pad worked as well as the rest of the machine. I ordered a replacement keyboard which was the complete top assembly from IFixit. I installed in and it still does work.
Any suggestions?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
In general, when I have something like this not work my first step is to re-open everything and make sure that everything I unplugged is plugged back in properly. Second, I'd visually inspect your boards for shorts as you spilled liquid on it.
Last you can send an email to support@ifixit.com to chat about some troubleshooting options if the problem is the new keyboard.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Jeffrey San George será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 6
Ao todo: 119
