Ir para o conteúdo principal
An SSD, or Solid State Drive, is a type of storage device that uses NAND-based flash memory to store data.
20 Perguntas Visualizar todos
mz-jpu512t/0a6 enclosure
Hello,
will this item fit a samsung mz-jpu512t/0a6 ssd (from a 2013ish imac)?
External M.2 SSD NVMe Enclosure
I didn't see any way to ask this question on the product page.
I extricated the drive and ordered what I believed was the correct enclosure, but I was mistaken. Looking through enclosures here and on amazon, I cannot find any that will fit this ssd.
Any help--any!--would be appreciated.
Thanks!
Imagem de Use an M.2 SSD as an external drive in this enclosure. USB 3.1 transfer speeds up to 10GB/s
Produto
$19.99
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
Is it the PCie based SSD? If it is, you should be able to buy an adapter. However, I do not believe that the product will out of box fit the SSD, and you will need an adapter.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Pat Foster será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 14
Ao todo: 274
