Kernal Panic when running zoom 1 year after SSD Replacement
Hi everyone,
I replaced the harddrive on my Macbook Pro Retina late 2013 with the WD Black SN770 NVMe SSD 1TB and this sintech adapter. https://www.amazon.com/Sintech-Adapter-U...
Recently when I've been running zoom (2 calls recently, 1 didn't cause issue) I've been getting kernel panics causing the computer to freeze and shut down.
I'm not sure if I should replace the adapter or if it is an issue with the SSD (which would be unfortunate since it's only a year old). I still have to run MacOS 10.14.6 due to some old software incompatible with newer updates.
Here are the last two error reports
https://www.dropbox.com/scl/fi/80s71ntg2...
https://www.dropbox.com/scl/fi/8ej20558u...
Let me know if anyone has any thoughts.
Thank you,
Daniel
Esta é uma boa pergunta?
