Ir para o conteúdo principal
The PINE64 PinePhone is the company's first phone. The phone comes as a black model with a temporary OS and features six kill switches as well as up to 2TB of internal storage.
dropped the phone, mic no longer works
I dropped my PinePhone and the mic no longer works so nobody can hear me on a phone call. How can I fix this?
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Solução escolhida
I have been having the same problem. It turns out (in my case), that if I plug a headset with a microphone in, then it works. If this is the case for you too, it could be a hardware problem. The microphone is located on the backside of the USB-C side board. I ordered a new one and installed it today. Thankfully it fixed the issue and the (new) internal microphone is now working.
Instructions: To replace the USB-C side board, you need to follow steps 1-5 of replacing the main board. Then the USB-C side board is glued in place, as explained in the note about the vibration motor.
Note: Doing the replacement yourself is a bit fiddly and requires the right precision tools, but definitely doable.
Esta resposta foi útil?
Pontuação 3
1 comentário:
This looks extremely helpful and I am looking forward to trying this... after I find my Pinephone which I misplaced/lost yesterday.
por
Adicionar a sua resposta
J T será eternamente grato(a).
Visualizações:
Últimas 24 horas: 6
Últimos 7 dias: 16
Últimos 30 dias: 61
Ao todo: 559
