Power stereeng not working
Esta é uma boa pergunta?
Check the fuse located under the dash for your electronic power steering module. If it's okay, then check the harnesses for the module itself for bad connections or corrosion on the terminals. If there are no bad connections, you'll have replace the EPS module itself more than likely.
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 6
Duração total: 55
