Ir para o conteúdo principal
Um fio é um filamento ou haste de metal flexível, geralmente cilíndrico.
3-way switch replacement help
I am trying to replace a double pole switch that is a few years old.
One pole is just for the porch light and one pole is for the hallway lights that has a switch on first and second floor as well as the this one that is by the door.
However, the new 3-way switch that I bought looks a bit different and am now confused as to which wire goes where.
Any help or info would be appreciated!
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Give this a read How to wire a three way switch
It can be a bit confusing and depending on colors of the wires your house wiring uses the two messager wires can confuse
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Al mirani será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 28
Ao todo: 314
