The saw blade release lever is stuck in the release position.
Blade release lever is stuck in the release position. How do I get it to the locked position?
Esta é uma boa pergunta?
Pontuação
0
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 17
Is this jigsaw clogged with debris? Can you clean off as much debris as possible then try a little WD-40 into the release lever and blade jaw? Some light rapping against the body with a mallet can help loosen dirt buildup with WD-40 loosening up a sticky mechanism.
por F Dryer
