Bostick Brad nailer not firing nails
Bostich Brad nailer SN1850BN not firing nails. No worn or broken parts and tool is lubed
Esta é uma boa pergunta?
Failure to cycle
Air supply restriction . . . . . . . . . . . . . . .Check air supply equipment
Tool dry, lack of lubrication . . . . . . . . . .Use BOSTITCH Air Tool Lubricant
Worn head valve O-rings . . . . . . . . . . . .Replace O-rings
Broken cylinder cap spring . . . . . . . . . .Replace cylinder cap spring
Head valve stuck in cap . . . . . . . . . . . . .Disassemble/Check/Lubricate
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 40
