Ir para o conteúdo principal
27" display with 2560 x 1440 pixels resolution Thunderbolt & MagSafe cable attachments
Apple Thunderbolt Display dim
Thunderbolt display dim problem
Today my thunderbolt display suddenly went very dim. I've tried turning it off and then back on again but it doesn't work. I tried to adjust the brigtness on the Macbook pro, when I moved the slider, sometimes the screen brightened and then went dark again.
Still unsure is this about the connection cable or the backlight.
Have any idea about this anyone?
https://youtube.com/shorts/hyUcPAxfNc8?s...
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
Sorry this looks like a much deeper problem that the Backlight! The strobing and lack of any image tells me the displays LCD panels T-CON or the logic boards display driver logic has a problem.
Time to find someone locally with display repair skills to hopefully isolate out which has failed. Even still you might find a used TB display for sale to replace yours or a cheaper way to get yours working depending on its state of working.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Steven Kin será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 12
Ao todo: 210
