press the power, the charging lamp will only blink once.
(Charger connected.)
(Charger is not connected.)
It mean should I buy new battery for DSi?
Or is the battery terminal is broken?
Esta é uma boa pergunta?
check if there is a battery in the dsi, if there is then the battery could be broken and needs replaced, and if that doesn't fix it then something is wrong with the battery terminal.
basically the dsi needs a battery to turn on and that battery needs to function
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Duração total: 30
