Ir para o conteúdo principal
Repair information for the HP EliteBook 840 G3. This Hewlett-Packard laptop is designed for enterprise usage.
Why is my brightness level is not responding
Brightness controller is not functioning
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
In my experience, this is often due to issues with your graphics driver. A simple check for a Windows driver update might help. Press the Windows Key and X. Select Device Manager from the menu that appears. Find the display adapters section and pop it open. You may even see it's open already if the issue has been detected by Windows.
Right click whatever your computer has listed as the Display adapter. Likely for you it will be an Intel Graphics device. Select Update Driver to see if a newer driver is suggested by Windows.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Semir será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 14
Ao todo: 527
