Ir para o conteúdo principal
Máquina de lavar LG "6 Motion Direct Drive" comercializada por volta de 2017. Código do produto FH4G6TDYW2.ABWQWFS.
Why is my washing machine not working properly
My issue is my washing machine is not washing clothes even if i add high quality detergents and the clothes still remain black and dirty
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
2 respostas
Pergunta mais útil
Try to clean your filter. Usually it is located on the bottom side if you remove the plastic cover. Also check if it doesn't take your detergent inside and clean the drawer too.
Esta resposta foi útil?
Pontuação 1
First clean the filter and run a drum-clean cycle. Make sure you are not overloading the machine and that enough water is entering during the wash cycle. If the problem continues, there may be an issue with the water inlet, sensor, or motor, and the machine should be checked by a technician.
Pontuação 0
Adicionar a sua resposta
Mohammed Riyaz será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 20
Ao todo: 503
