Xiaomi 11t pro. Battery stuck at 15%
Hello, I have a problem with my Xiaomi 11T Pro. The phone froze at 15% battery charge. Neither a software update or a battery replacement helped. What could this be?
Esta é uma boa pergunta?
If the new battery didn't solve the problem, most likely the problem is at power management ic on motherboard. Also common issue of false battery percentage is a bad connector.
Esta resposta foi útil?
I also have the same issue, my xiaomi 11t pro didnt increasing, but the overall performance of the phone is okay and smooth, just the battery concern stuck in 15%, i think the battery is need to replace a new one...
It same like mine after updating to HyperOS, I was thinking it because of update but after I go to store any said that I need to change the charging dock assembly to fix the ploblem!
Últimas 24 horas: 4
Últimos 7 dias: 66
Últimos 30 dias: 336
Duração total: 3,083
@oldturkey03 The phone works well, it charges correctly, but it always shows 15% battery charge, no matter if I discharge it or charge it. I also replaced the battery connectors, but it didn't help.
por Gustek
It's a hardware problem, I fixed it opening the phone and pressing the battery connectors
por ssss
@ssss17468 this is the best answer, i already solved my problem
por Romano Raul Romulo
