Ir para o conteúdo principal
The Land Rover Defender (initially called the Land Rover Ninety and Land Rover One Ten) is a British four-wheel drive off-road vehicle developed from the original Land Rover Series launched in June 1948.
Noise when clutch pedal is depress
Landrover defender 130 td5 after i have replace the clutch kit and thrustbearing when i depress the clutch pedal there is a noise sound like gears running with out oil but with the clutch pedal still depressed and selecting 2nd gear the noise go away but when i select any other gears the noise comes back even when in neutral but when i release the clutch pedal the noise is gone can it be something in the gearbox or the spigot bush that cause that noise. Thanks Max.
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Without more info on what kind of clutch system you have I would have to say you probably need to bleed the clutch system at the slave cylinder
Esta resposta foi útil?
Pontuação 0
1 comentário:
I have fitted a new clutch kit and thrustbearing a new clutch master cylinder and a new clutch slave cylinder the clutch have been bled about 3 times already but the noise stay there.
por
Adicionar a sua resposta
Max IRMSCHER será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 35
Últimos 30 dias: 83
Ao todo: 634
