My black E7 headphones won't play any sounds
The lights turn on but it won't play any sound
Esta é uma boa pergunta?
Hello, after doing some searching, I've found that it may be a bluetooth connection issue. What this means is more than likely an issue with the device you're trying to connect to instead of the headphones. I would recommend checking if all your software is up to date or a simple reset should do. If the problem persists, then I would recommend following this troubleshooting guide. I hope this helps!
Esta resposta foi útil?
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 22
Duração total: 108
