Ir para o conteúdo principal
Philips 55PUS6704/12 broken backlight or PSU?
I have a Philips 55PUS6704/12 that's maybe 3-4 years old now (out of warranty). When i turn it on the ambientlight comes on and the Philips logo flashes really quickly the just a black screen. If i shine a flashlight on it i can see the menus and stuff like that.
I've taken of the back and measured the voltage at - VLED (5.34v) and + VLED (25.5v) measure against ground.
How can i find out if it is the board that need's to be replaced or the LEDs?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
After some research i took a shot and bought the backlight LEDs and after replacing them the TV worked fantastically. one important thing i missed when reassembling all of the LCD layers is to watch out for the bits of foam holding the LCD from falling in behind or between the layers.
Esta resposta foi útil?
Pontuação 2
1 comentário:
hi, do you mind sharing where you sourced the replacement backlight?
por
Adicionar a sua resposta
Linus Höggren será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 7
Últimos 30 dias: 18
Ao todo: 182
