Ir para o conteúdo principal
The iFixit Precision Bit Driver is an aluminum or plastic handle that fits 4 mm bits. Found in the Manta, Mako, Moray, Mahi, Minnow, Essential Electronics, Pro Tech and Pro Tech Go Toolkits from iFixit.
Bit stuck in tool due to super glue
Hey, I made a mistake and let small drop of glue into screwdriver, now it’s impossible to take off the bit.
Any idea how to dissolve it?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Hello! Have you tried rubbing alcohol or another solvent? Acetone is also quite good for dissolving adhesives, but im not sure how this would react with the paint on the driver. @aleks26378
Esta resposta foi útil?
Pontuação 0
2 comentários:
I tried to put a bit into nail polish remover but no effect. Maybe rubbing alcohol could help. Thanks for the answer!
por
@aleks26378 No worries! Hopefully you have some luck with it.
por
Adicionar a sua resposta
Aleks será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 6
Ao todo: 157
