iPhone xs shut down automatically while charging. see the Panic report
My iPhone XS shut down automatically while charging. After removing the charging cable it turns on automatically. Issue doesn't appear while charging using wireless charger.
Here is the panic report-
panic(cpu 1 caller 0xfffffff011dae3a8): "i2c0::_checkInterrupts error interrupt; last read status 10810100 int shadow 00890100 xfer 80000000 fifo 00000003 for device ad5860" @AppleS5L8940XI2C.cpp:451
Debugger message: panic
Memory ID: 0x1
Possible issue-
''U4700 Big Audio Codec IC
Baseband/NFC
i2c0 line
U2700/U6110/J6400
NAND
Wi-Fi Module''
I have checked other threads. Some guys are saying that its because of charging flex and suggesting charging flex to replace. Some other saying that its because of taptic engine.
Would you please tell me whats the report saying actually and what should i do?
Thanks
Esta é uma boa pergunta?
2 comentários
@flannelist, if you have time, take a look. I probably won't be able to get to my XS schematics till tomorrow. I've got a set of XS Max drawings handy, but I hesitate to generalize between the two.
por Jerry Wheeler
Have you solved you're problem ? because i have the same issue with my IPhone XS
por Danieljr0074
