Ir para o conteúdo principal
The Samsung Galaxy A71 is an Android smartphone manufactured by Samsung Electronics as part of the Galaxy A series. It was released in January 2020. Versions: SM-A715F/DS, SM-A715F/DSN (Global), SM-A715F/DSM (Russia).
Do I need my screen replaced if I have white vertical lines on screen?
Do I need to get my screen replaced if I have white vertical lines on my screen and they kept on growing in numbers. it was just one vertical line but now i have no idea, it covers 1/6 of my screen. also, it's at the middle and I can't use the fingerprint sensor coz it won't read my fingerprint. Ive dropped it many times and there are cracks on my screen, I'm wondering if the white lines will still appear if I replace the screen on my own.
Esta é uma boa pergunta?
Pontuação 12
3 comentários
I have these white vertical lines as well on my screen, and increasing almost daily. No physical damage, phone was not dropped. Problem started after recent software upgrade...
por
I'm also having the same problem ,but the number of vertical lines are 4 ,initially it was 1 and it increases .Fingerprint sensor is not working properly sometimes .what should I do ?. Do I need to change new screen .
por
@harshabala82056 Yes, the lines on the screen are indicative of damage to the connections between the glass and the flex cable. Those connections cannot be repaired, so the only fix is to replace the screen.
por
Adicionar um comentário
1 resposta
Pergunta mais útil
Hi Ras,
It would help if you posted a picture of what you're seeing on the screen, but chances are high that you do indeed need a new screen.
I can't be positive, but I'd say it's very likely your fingerprint reader will work again once you've put a new screen on. If not, the good news is the actual reader itself can also be replaced if need be. Regardless, all of your issues with cracks and lines will be resolved with replacing the display. iFixit doesn't have a guide for your phone, but there's a Spanish site called Nadie Me Llama Gallina that has just what you need.
Manuales / Samsung Galaxy A71 / Fullscreen
You can get replacement parts on many different sites; I usually start with Amazon, eBay and AliExpress, but there are lots of others to choose from. Here's an example.
Amazon.com: YWLRONG for Samsung Galaxy A71 Screen Replacement Display Touch Screen Digitizer LCD for Samsung A71 A715F SM-A715F/DS SM-A715F/DSN A715FD Display Repair Part(Black with Frame) : Cell Phones & Accessories
Good luck with your repair; let us know how it goes!
Esta resposta foi útil?
Pontuação 1
2 comentários:
thank you, I checked the website and it'd be a very helpful guide on changing the screen
por
@rasjaener Thanks for the picture, Ras. It confirms that you definitely need to replace the screen.
por
Adicionar a sua resposta
Ras Jaener será eternamente grato(a).
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 16
Últimos 30 dias: 48
Ao todo: 1,815
