Electrolux EX600 wont finish cycle and trips power
Washes and drains fine, but just stops short of completing cycle, leaves a small amount of water in sump and trips power. After resetting power, works again , but repeats failure mode again. Seems to be temperature related.
Esta é uma boa pergunta?
Pontuação
0
Hello quick question does it display any error codes to you?
por MexGeek
@mexgeek Not That I'm aware. On the otherhand, presumably any messages would be lost when the power trips out. When I reset power by unplugging and re connecting the washers all seems to work, but repeats the same problem, finishing just short of final drain and dry
por Tony W
Grateful for any ideas any ideas , otherwise its a trip to the rubbish tip !
por Tony W
