Ir para o conteúdo principal
Repair information for the Philips Saeco Intuita espresso machine.
4 Perguntas Visualizar todos
No coffee onyl water coming.
If i turn on the system rinse do nothing. If i put in test mode and i test from the water pipe is coming the water if i try water from the "central" from where the coffee is need to come nothing happened. How can i fix it?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Did you see the parts diagram: philips_saeco_hd8750_hd8751_hd8752_espre.pdf
(1)The pump seems to be OK!? Really? Perhaps it it to weak.
(2) So I would have a look for the solenoid valve (using the test mode) or the
(3) support valve as seen in this answer Coffee ends up in waste container
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Zsolt Uszkay será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 73
