iPhone 14 Pro proximity flex swap issue
Hi I have been working on a 14 pro with a faulty proximity sensor, I swapped the sensor once to no avail the phone was still appearing with smc bsc failure in the panic log. so after testing a few things and trying more fixes we assumed it was a faulty sensor that arrived. new sensor arrived and the phone worked fine until a data transfer was attempted then it went back to the 3 minute restart glitch. just wondering if the screen could be causing the issue as its the only part that hasn't been swapped or tested on the phone. Thanks
Update (09/11/23)
attached is the panic log for the 14 pro, btw new screen didn't fix the issue.
Esta é uma boa pergunta?
1 comentário
Let's take a look at the first page or so of the panic log you're getting. Between @flannelist and myself, we're getting pretty good at figuring out where the problem is coming from based on the log.
por Jerry Wheeler
