Ir para o conteúdo principal
A home theater system released by Sony in 2010.
2 Perguntas Visualizar todos
Why is my Sony music system not starting
My music system is not getting connected
Esta é uma boa pergunta?
Pontuação 1
2 comentários:
@anoopkumar82932 not connected to what? does the power come on? what does it do? We need more real information if you are serious about getting this fixed.
por
Hello expert, mine fails to power up and I've connect it to the outlet when I click the power button firstly it displays hello for like 30 seconds and then it turns off, after that when I repeat to turn it on it gives like some soundwave straight from the amplifiers inside but does not power up
por
Adicionar um comentário
1 resposta
Make sure your music system is connect to the outlet and there is electricity supply around your area for it to power up, if it fails try to power on using a remote controller may be your button has problem.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Anoop Kumar Satsangi será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 12
Duração total: 125
