How do I replace the USB -c ports on this Chromebook?
The usb-C ports are no longer charging the Chromebook and need to be replaced. How do I do this?
Esta é uma boa pergunta?
Hi Diane,
Generally when you need to replace a charging port, you've got two choices. On some devices the port is mounted on the motherboard so short of replacing the entire motherboard, you have to unsolder the old USB port from the circuit board and solder on a new one. USB-C ports are more difficult than the older USB versions in that they have many more pins and tend to need more advanced soldering skills and tools in order to replace them. As an example, this port should fit your Chromebook but as near as I can tell it probably takes a hot air station to remove and replace the jack.
Type-C USB Charging Port DC Power Jack For Asus CHROMEBOOK C302 C302CA US GAN
However, other devices like yours sometimes mount the charging port on a smaller, separate circuit board that is easy and cheap to replace. Definitely a preferable way to go unless you are really pinching pennies and really good at soldering. They seem to be available both new and used, so it's up to you which way you want to go; the new ones are aftermarket parts and will probably work fine but you sometimes take a chance with them. Otherwise you can pick up a used one on eBay that will be made by Asus, but of course it is used so hopefully it won't come with any problems. Here are a couple of examples I ran across; if you search for the part number you can likely find more.
Asus Chromebook Flip C302C Audio USB Type-C Board w/ Cable 320Q5IB0000
As far as how to replace that part, there's a guide available that shows you how to replace both it and the motherboard but it looks to me as though you could probably skip a lot of the removal that's not necessary for replacing what the guide calls the daughter board. I doubt you have to actually remove the motherboard so I'd leave that in place and just try taking out the daughter board first. The battery too; it's not obvious that you'd need to remove it for the daughter board either.
Asus Chromebook Flip C302CA Mother & Daughterboard Replacement - iFixit Repair Guide
Hopefully that'll get you going again; it doesn't look like to difficult a repair if you go with the board and not just the charging port itself. Good luck and let us know how it works out!
Esta resposta foi útil?
Últimas 24 horas: 7
Últimos 7 dias: 21
Últimos 30 dias: 113
Duração total: 537
@dianem507 Can you confirm exactly which Chromebook model you have?
por Alisha C
I would love this answered for the Samsung XE530QDA-KB1US
por David Farwell
